Presume it has the OSP5000L-G control? or OSP5020L?
Either way, is there any programs in memory?
If so, press the Auto Mode key, you should then see "Program Select" appear above the F1 key. Press F1 then * and then the Write key.
You should then see a list of programs that you can select from.
Does your machine have IGF?
Really need more information to go any further... Need to know exactly what controller you have on your machine?
I used to program and run a LC20M 4 axis with in process gauging and a small robot, great machine.
Cheers
Brian. |
