Old 11-08-2009, 06:00 AM
hartan hartan is offline
hartan is on a distinguished road
The machine is now a month working normally, but today I had the same problem reappeared. The difference being that changing tool was not even possible. I can only hand tool clamping. When I turned on the rpm (eg. 3000) with clamping tools, the entire steering froze and I had to turn off the main switch. rpm it was turned on only when the taper is empty. I suspected malfunction of the sensor to detect pushed piston plate. By using ˝DI ˝ and ˝ DS˝, I then checked the detection sensor and found that we are trapped in the tool remains ˝ 1 ˝. Finally I realized that we are trapped in the gear sensor detects the magnet in the panel even when the drawbar rises. Are trapped in the tool plate is 4 mm lower than the empty taper (is that normal?). When I sensor magnet plate taken place a little lower, the sensor also are trapped in the tool losing signal.
Now I have a sensor and therefore slightly lower clamping function normally. I wonder if this may be due to some other problem whether this is normal right?
I hope someone understands, my English is bad ...
