Old 03-08-2005, 03:51 AM
Apples's Avatar
Apples Apples is offline
Apples is on a distinguished road
What to use for rails/ways? pipe, mild, 304, box
What would be the best to use for a rail/way to run ABEC7 bearings on for a gantry? I went Metalcorp, this afternoon to look at different bits of steel to use as rails to run bearings on.
The choices that I had come up with were:
1. mild pipe 25mm up to 40mm diameter
2. mild flat 100mm x 8mm
3. mild bar 25mm x 25mm
4. stainless steel 304 grade pipe 25mm-40mm
5. brite (bright????) mild steel shafting 25mm
All of these types of steel are to have bearings running on them. I was going to use the 100x8 flat bolted to the side of my table, but I noticed how wobbly it was when I look along it, so I won,t be using that.
With the pipe steel, out of the mild or stainless which one would be the straightest and have the tighter tolarance?? Any ideas on what the tolorances exactaly are??
I was also told by someone that the brite mild steel shafting was pretty straight and that it might be better to use.
I am ready to spend money and move onto the x,y,z stage of my machine, can someone please help me out?
Cheers Peter
