Old 11-06-2009, 08:49 AM
Drools's Avatar
Drools Drools is online now
Drools is on a distinguished road
I'm in the same boat as Calico, I have several double sided designs that I would like to try but when flipped in eagle the image always ends up in the negative range and my router 0.0 position is the limit it can go. If I had my router setup so that 0.0 was somewhere in the middle of the routers range then flipping would not be a problem. Lining up the board perfectly would be the next issue.
Bubba, would you mind maybe doing a brief how to on the process you are using?
