I'm starting a project for a rotary (4th axis) on a excitech machine...my big question is. It's possible to add the rotary on a excitech (shm2030a), dsp model (the controller only handles 3 axis... so i heared). The idea is to physical swap the wire from the X axis stepped motor with the wire from the 4th axis stepped motor ( it's important to say, the stepped motor that i use for the rotary will be the exact model whitch it's on the x axis). W8ing for idea's...Tx
