Old 11-03-2009, 10:39 AM
schouten_tjeerd schouten_tjeerd is offline
schouten_tjeerd is on a distinguished road
You have to adjust the "Distance Threshold".
Find any parallel tracks you want to remove. Get the X or Y offset between the two. Set the distance threshold just a tiny bit larger than that. Be sure to use the same units as your gcode file.
It looks like you have your distance threshold set far too large so the program removes all sorts of tracks you don't want it to. Besides, I don't see any tracks in your program you want to remove anyway. Remember, it is only designed for fine pitch SMD pads which have only two tracks in between them.
Tjeerd
