Old 11-03-2009, 08:24 AM
achavarria achavarria is offline
achavarria is on a distinguished road
When I calculated, I use a formula from any stress and strain text book. I use a two bearing supported shaft. The formula for the max deflection at the center is
dx=(PL^3)/(48EI). If you change the steel, the modulus E will not vary a lot, you will not gain much using another steel. I you want less than 0.004 I suggest to increce the diameter of the shaft.
