DXF export from Corel - Text cutting | | Is this the only way?! I export from corel as DXF V10, import into BobCad, and I have to select these tinyline/arc segments in the middle of each letter to move to layer 1!
Why are the line/arc segments broken? The font was converted to curves before exporting. This always works with vinyl cutters. A 3 Axis router is only 1 axis more than a vinyl cutter. So what, you're only changing the Z.
You have to cut the middle first, then cut the outside when cutting completely through. So, any text must be in 2 layers.
Seems by default "Mach2" always cuts outside first. This will cause the font letter inside to rip out.
Ideas? |
