  #11   Ban this user!
Old 11-01-2009, 03:53 PM
Eclipze Eclipze is offline
Eclipze is on a distinguished road
Originally Posted by Jay C View Post
The acceleration was at 20, now at 80. I use Quantum and the path smoothing feature. Jerk is set to 200"/s^3 with a 2% adaptive. I've long since forgotten why I chose those values I reran the circuit (this time with a V-Bit). It's no faster than the video, but jogging is improved. Again, I suspect there just isn't enough room to go full speed.
Now for a math question (before I go to Google to help): I really like the quality of the ball nose cut on this copper. Can some one tell me the trig equation to find the diameter of the bit at a specified depth of .003"?
Thanks,
Jay
The math for it is....
Given,
W = width of the cut at the specified depth
D = Diameter of ball nose
z = depth of cut
W = sqrt[D - 4(D/2 - z)^2]
So if you used a 0.04 diameter bit at a depth of 0.003, then the width would be 0.021.
But you also need to take into consideration the thickness of the copper. If you take 50um copper clad board, then your effective cut width reduces to 0.013 (almost half).
