  #11   Ban this user!
Old 10-31-2009, 01:21 AM
dcoupar's Avatar
dcoupar dcoupar is offline
First off, MysticMonkey is right on. It's always better to start your own thread rather than hijack one. Things can get real confusing with people responding to 2 or 3 different problems.
A 2007 240MS doesn't have a Y axis and it does have a BMT turret (not VDI) - all 12 stations are identical.
If this has been a problem since you got the machine then it is possible the previous owner bumped the X axis down onto the sub-spindle and shifted the zero, or run into the chuck jaws spinning the turret (that would explain the turret being off in Y).
You should indicate the turret in X and Z to see if the turret is out of alignment or possibly the headstock is out of alignment. If everything is square, then you should be able to reset the X home position to get things back in order.
I'll look for the procedure in the morning.
