I recently
completed most of the Steele mini-lathe conversion and it works flawlessly with Mach3 (which is great software).
Mach3 will eventually support the G71 and G70 (rough and finish turning cycles respectively), and it already provides conversion from dxf to G-code, but is there any hobbyist-priced software that will convert either dxf or finish profile G-code to all of the necessary roughing G-code?
Thanks for any software links or tips that you can provide.
