  #12   Ban this user!
Old 10-29-2009, 09:08 AM
scrambled scrambled is online now
scrambled is on a distinguished road
Jeff-
In your post #7- Those wires are "Common"
For the charge pump for the VSD, I installed the jumper to by-pass this. Once I get everything running, I will install it.
I will have to check the Jumper 2-3 setting. I think this is set correct, because on my multi meter I can see the +5 volts for "direction" for each axis.
Which xml file are you talking about? I set up the candcnc bob acording to the instructions, and I am using their plug-in for Mach3. This sets all the ports and pins.
I will set up a instant messenger. Do you have one you like to use?
Thnaks for the help
Steve
