Originally Posted by 10bulls Under profile and pocketing machining options, there is a property called 'LeadInMove' ... there is a [+] symbol to the left of it which expands to sub properties.
It sounds like you need to set the LeadInType to Tangent, then also define the TangentRadius. You can also put a value in the SpiralAngle so that it tangents in and spirals down simultaneously.
For pockets, it *should* start from the center and work it's way out by default.
You can also define a lead in move - this time a LeadInType = Spiral is useful, together with the Spiral Angle.
You may notice there is also a LeanInFeedrate parameter. If 0, this will use the cutting feedrate. Any other value overrides this.
Setting the precise start point is a little tricky in the current version and involves changing polyline start points.
I am about to put out a new version that allows you to simply pick a start point for each machining operation. A test version of this release will be out soon.
I hope this helps! |
Wow, you really did think of everything.
