I installed the version 1.3. I used the 'Update Program' option, selected the 'RZNC-D5416-1.2(zhb981)_normal.NEWBIN2' file and the message 'Normal program updated!' appeared, but again this had no effect at all on the DSP.
I have an idea: could you use the 'Backup Configure data' (below the 'Operations' menu) on your PC?
It seems that option will create a backup of the information stored in the DSP (probably including the firmware?). When you generate the backup file (.dat), please send it to me. Then IŽll try to restore my DSP using your backup file. I donŽt know if it will work, but I canŽt think any other solution.
Originally Posted by Big S I think the .dat file is one that you can save from your DSP, It saves all the step pulse settings and user changeable DSP settings. It doesn't save the inbuilt software. (I think ) |
Probably youŽre right, but my only hope is that youŽre wrong
Otherwise I think IŽll have to send my DSP for repair...
