Originally Posted by 11toma FastFieros,
Were on the control does it list the buffer? This is interesting, I was running some G-10 on my CNC this weekend and the feeds I needed to run would give me the jerking you spoke about. This happened when in tight corners or arc movements. I was not cutting this on my Fadal, but I believe it has something to do with look ahead, or buffer. Would be nice to see what the buffer was. Another question there is no way to make offset adjustments on the Fadal 88 while in auto mode is there? Tom |
On the Fadal screen version SYS97.3 and above, it shows the BUFFER information on the screen while cutting. Pic attached
Oh my gosh, you cannot imagine how I wish there was a way to just tweak the offset X Y Z while in auto running mode. If it would only adjust .005 plus and minus I would be a happy camper. Bad thing is that if you generate your code with like MasterCam and dont use the G49's, then you dont even get to comp offset with D= either. I have had problems with my post processor using the comp wear feature in MC, so I dont use it.
