Hi Sorojchi.
data exceeds working table that is because orientation wrong.
laser does the same shape over and over again that is because the "times" parameter
you makes more than 1 times.
You can engraving a 2cm diameter round, then choose "immediate", the location where
laser head stopped is the point where the laser head will start next work.
if it still engraving over and over again, that is panel have some problem.
you can plug out the panel, then test.
It is hard to repair a machine by words only , please send videos to the girl who had sold you machine, she will connect engineer help you.
Cici
www.wklaser.com
