Is there an Html Link (or freeware of somesort) that can allow you to input your differant conditions (Cutter #Flutes, Cutter material, stock material, side milling plunging, drilling or whatever)
and output a rpm and feed rate?
If not is there recommended software that specializes in this. I use Pro Manufacture.
I've obtained a Machinist Handbood (that is almost as thick as it is wide) but I don't have the patience for it. Maybe there is another text that is a bit more specialized in what I want.
Tony
__________________ xeno@xenomechanics.com
http://www.xenomechanics.com |
