Originally Posted by Crevice Reamer It's just a coil. Volts is Volts. DC can energize an AC coil. It should work fine.
CR. |
No, the DC resistance of an AC coil is too low to use it on DC, the AC coil relies on inductive reactance to limit the current.
This is why a AC solenoid or relay will burn up quickly if the armature does not move over, due to the decrease in inductance, just leaving a very low resistance.
