when cutting why not leave bridges and route in a cut sheet #. assosiate the cut sheet # with the template or assymbly drawings so if you have multiple parts in one sheet you dont knock it out until its ready to be put together just like in a model.. if you want to # it and dont want to damage the peice and if the cutter is fine enough you can route the # or part # below or in room. |
