Thread: charge pump
  #12   Ban this user!
Old 10-13-2009, 06:34 PM
phomann's Avatar
phomann phomann is offline
phomann is on a distinguished road
Originally Posted by michaelf View Post
Thanks everybody for all the information.
Some more questions, should I be turning things on in any particular sequence? Meaning should I be turning the controller on before the PC or vice versa, should I be turning the controller on with the e-stop push in?
My problem at the moment is that if I have the charge pump switched on and the switches set in Mach3 as recommended by Geko I get a red error light, if I switch the charge pump off on the Geko I get a green light. However, I can toggle the arrow keys and see movement on the DRO's, but nothing happens at the stepper motors, where should I be doing or where should looking to prevent the red error light from coming on, what haven’t I done?
I did load the setup file from Geko but there where too many things included in that file that I am not using at this stage, so I made my own settings to Mach3 as required, even so I still can’t get any movement out of the steppers.
Mike
Hi Mike,
What you need to do is go into Machs general config and tick the Charge Pump in EStop checkbox.
That should fix it.
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
