Originally Posted by CNCRouterMan There are a few things that can cause this problem. You need to go in the bios and see if the bios can see the hard drive. Most computers today only use the battery for the time set. If the bios does see the hard drive then you might have a problem with the drive. If it doesn't see the hard drive you might want to make sure that the cables are pluged in. Unplug all the cables and reseat them and see if that works. |
The system we are running is about 20 years old, when i go into the bios it shows that the primary drive is there but if you go in to dos you cant access it via the c: path. i will check the bios battery and do as you suggest. cheers JB
