Thread: techno-retro
Old 10-10-2009, 11:57 PM
g2x2y2 g2x2y2 is offline
g2x2y2 is on a distinguished road
Typically you don't need a counter balance on a stepper system. when you turn your machine off with steppers, the z doesn't drop like the servo system does. but also the stepper sytem is much easier to setup and less expensive. if you you do go with steppers. i recommend that you wire them in parallel. 2 sites to check out. kelingcnc.net and homeshopcnc.com
