You would get better responses in the mastercam section
But,
in V9, you have to be able to get lines and arcs ( some say vectors ) onto the screen ( you may need odditional software- not sure )
You then select these entities, define a tool ( taper is the normal selected tool, but it is your choice ) and to make the tool follow them , cutter compensation is OFF, you select the top of stock and the depth settings and you're off and going
PS. I forgot to add that "lead in / outs" turned OFF, and XY offset to zero
