My first refit was from a bandit to AHHA. back when DOS was king. I changed this machine over to Mach2. At the time I thought AHHA about the same. sence then AHHA has died and Mach has improved. i'd make the change just for support issues.
I later refit this machine again to Camsoft. Attached is an install notes that will tell you functions on the DB37 connector on your AHHA step drive box
Karl |
