Thread: Problem 6030 X-axis
Old 10-09-2009, 07:01 PM
Delw Delw is offline
Delw is on a distinguished road
Originally Posted by MMI View Post
I have a 94 VMC 6030 and the x axis is acting funny. I checked the gibs and they seem to be set right. The x axis seem to be rumble in when it rapids just in the – direction. Some times you can even see it on the part when it’s milling. Its like it stops then jumps .01 to .02 and keeps doing that. When it gets that bad I shut it off and restart and it helps. Enough so you can’t see it on the part but if you put your hand on the table and jog it as fast as it can go you can feel it slightly. What I would like to know is it the motor is it the thrust bearings or something else that I need to check.
Jay
Jay I have the exact same problem with my 40x20 I checked everything even oiled the ball screw manually and ran it a few times just to make sure. no changes.
in the x- is were mine is loudest and very slight in the x+
I have a new motor on the x axis and thought that would fix it. Mine was running like that since I got it (completely rebuilt supposibly) and its only in rapids at 100%
at first I thought it could have been the axis motor coupling, not being aligned correctly but after replaceing the axis motor it made no difference.
I am thinking but not sure maybe a thrust washer? or something on the opposite side of the axis motor is slopping around or not true. either that or its the drive board, I havent swappped the drives yet but its on my list of things to do , to find the problem.
if its not electrical then it may even be were the ball nut mounts to the table, maybe it came loose?
I have no problems with positioning or tolorances just the noise/vibration sounding.
I have heard this same noise in the past rebuilding acrolocs and its generally due to the ball screw not being centered properly opposite of the axis motor However yours is 60" and if you have the slightest bind in the ball screw(off center) even on the axis motor side you will hear it.)
Delw
