Thread: Need A Quote Turning/Milling Job
Old 10-09-2009, 10:08 AM
millman52's Avatar
millman52 millman52 is offline
millman52 is on a distinguished road
Turning/Milling Job
Please find .dxf & or .dwg print enclosed
Quantity of 20 pieces
Return quote & any questions to mullinsmachining@hotmail.com
The print shows part OAL of 11 3/4" I also need 20 of the same part with OAL of 7 3/4"
All sharp edges must be deburred.
Part can be machined from either DOM or HR tube. Material needs to be a weldable grade of mild steel.
Overruns of parts will be accepted in pairs of each. So you may bid using full lengths of tubing to minimise scrap & keep bid as low as possible.
Use this drawing for bidding purposes only. An approved final copy will be furnished to winning bidder. If any editing of drawing is done it will be to base size only tolerances will remain.
Total # of parts (40)
Bidding will end 10/16/09
Please give a shipping quote to ZIP 25164
If it works.....Don't fix it!
