Geof,
Sorry if this is a noob question, but when designing a fixture like that to hold multiple round parts. What size ID of hole in the fixture did you machine, knowing that it will clamp down on a part that is "X" inches OD.
For example if your parts are 2.000" OD, what size ID of circle did you machine out of the fixture?
Would you machine the hole the same dimension or ever so slightly smaller to ensure a tight fit once clamped?
__________________ Supermax YCM-40 Mill, Mach3, G320's, RogersMachine, PMDX-122 ---- Slowly coming up to speed... (that's me, not the machine) |
