gosh if i had the time i would knock these out for you. we do alot of stainless work and 316 isn't any worse than 321 or 304. insert grade is critical. get a special stainless grade insert. you can then run about 450-550 sfm. definitely get the speed up we run about .008 IPR through hex with no problems. depth of cut can vary. you have a short part and it won't stick out very far. i would take about .080 on the doc and knock those parts out. |
