Well I've made a little more progress. Still having problems with tool calls. After the Tool Call and Stop commands, the control refuses to continue with the program. The "spider," or asterisk flashes. I spoke with Heidenhain and an ex-B'port tech, and they suspect the control is hanging because it has not quite made position. Doing some basic linear moves, it stops at the programmed position. However that position oscillates .005mm or so. Is that bad? Servo drive issue?
Thanks for the help!
Kevin |
