Thread: G-Code to DXF
Old 03-01-2005, 10:09 AM
WayneHill's Avatar
WayneHill WayneHill is offline
WayneHill is on a distinguished road
G-Code to DXF
This program will convert a standard line-arc gcode file to a DXF file.
It is written in PowerBASIC and is released to the public doman.
http://www.cnczone.com/modules/Downl...file.php?id=22
Code:
#PBFORMS CREATED V1.50
' The first line in this file is a PB/Forms metastatement.
' It should ALWAYS be the first line of the file. Other
' PB/Forms metastatements are placed at the beginning and
' end of "Named Blocks" of code that should be edited
' with PBForms only. Do not manually edit or delete these
' metastatements or PB/Forms will not be able to reread
' the file correctly.  See the PB/Forms documentation for
' more information.
' Named blocks begin like this:    #PBFORMS BEGIN ...
' Named blocks end like this:      #PBFORMS END ...
' Other PB/Forms metastatements such as:
'     #PBFORMS DECLARATIONS
' are used by PB/Forms to insert additional code.
' Feel free to make changes anywhere else in the file.
#COMPILE EXE "G-Code to DXF"
#DIM ALL
'   ** Includes **
#PBFORMS BEGIN INCLUDES
#IF NOT %DEF(%WINAPI)
    #INCLUDE "WIN32API.INC"
#ENDIF
#PBFORMS END INCLUDES
#INCLUDE "COMDLG32.INC"
#INCLUDE "C:\QVCS LIB\Workfile\PowerBasic\Common\URL\url.inc" ' Add Urls
'   ** Constants **
#PBFORMS BEGIN CONSTANTS
%IDD_DIALOG1 =  101
%IDC_BUTTON1 = 1001
%IDC_BUTTON2 = 1002
%IDC_LABEL1  = 1003
%IDC_LABEL2  = 1004 '*
%IDC_LABEL3  = 1005
%IDC_LABEL4  = 1006
%IDC_BUTTON3 = 1007
%IDC_LABEL5  = 1008
#PBFORMS END CONSTANTS
MACRO Pi = 3.141592653589793##
    TYPE TypPoints
        X AS SINGLE         ' Center of first circle or first point of intersection
        Y AS SINGLE
        Z AS SINGLE
        I AS SINGLE
        J AS SINGLE
        X1 AS SINGLE    ' Center of first circle or first point of intersection
        Y1 AS SINGLE
        X2 AS SINGLE    ' Point on diameter of circle or second point of intersection
        Y2 AS SINGLE
        R AS SINGLE         ' Common Radius
        Ang AS SINGLE       ' Angle of Radius Point on Circomference.
    END TYPE
    GLOBAL TypOld AS TypPoints      ' Hold Values of Geometry
    DECLARE SUB CalcCenters( BYREF Centers AS TypPoints )
    DECLARE SUB CalcAngle( BYREF tPoints AS TypPoints )
   DECLARE SUB PARSEFILE( hWnd AS LONG,SMYSOURCEFILE AS STRING )
    $ALPHA = "ABCDEFGHIJKLMNOPQRSTUVWXYZ"
    $DP = "#.0###"      ' FORMAT OF XYZ - CODE
'   ** Declarations **
DECLARE CALLBACK FUNCTION ShowDIALOG1Proc()
DECLARE FUNCTION ShowDIALOG1(BYVAL hParent AS DWORD) AS LONG
DECLARE FUNCTION ExeName(Op AS LONG) AS STRING
'   ** Main Application Entry Point **
FUNCTION PBMAIN()
    ShowDIALOG1 %HWND_DESKTOP
END FUNCTION
'   ** CallBacks **
    SELECT CASE AS LONG CBMSG
        CASE %WM_INITDIALOG
            ' Initialization handler
        CASE %WM_NCACTIVATE
            STATIC hWndSaveFocus AS DWORD
            IF ISFALSE CBWPARAM THEN
                ' Save control focus
                hWndSaveFocus = GetFocus()
            ELSEIF hWndSaveFocus THEN
                ' Restore control focus
                SetFocus(hWndSaveFocus)
                hWndSaveFocus = 0
            END IF
        CASE %WM_COMMAND
            ' Process control notifications
            SELECT CASE AS LONG CBCTL
                ' /* Inserted by PB/Forms 10-11-2004 00:36:51
                CASE %IDC_LABEL5
                ' /* Inserted by PB/Forms 09-11-2004 15:16:59
                CASE %IDC_BUTTON3
                    IF CBCTLMSG = %BN_CLICKED OR CBCTLMSG = 1 THEN
                      DIALOG END CBHNDL   'Exit
                    END IF
                CASE %IDC_BUTTON1
                        DIM InputFile AS STRING
    Inputfile = "*.cnc;*.txt;*.dnc"
    IF OpenFileDialog(0, _
        "Open PowerBasic Source File", _
        InputFile, _
        CURDIR$, _
        "CNC Files (*.cnc;*.txt;*.dnc)|*.cnc,*.txt,*.dnc", _
        "cnc", _
        %OFN_FILEMUSTEXIST OR %OFN_HIDEREADONLY) THEN
    END IF
     IF Inputfile = "*.cnc;*.txt;*.dnc" THEN Inputfile = "None"
  CONTROL SET TEXT  CBHNDL , %IDC_LABEL1,  InputFile
                    END IF
                CASE %IDC_BUTTON2
                    CONTROL GET TEXT  CBHNDL , %IDC_LABEL1 TO  InputFile
                    IF Inputfile = "None" THEN EXIT FUNCTION
        ' Disable system menu's close item
        MENU SET STATE GetSystemMenu(CBHNDL, 0), %SC_CLOSE, %MF_GRAYED
        ' Disable other controls
        CONTROL DISABLE  CBHNDL, %IDC_BUTTON1
        CONTROL DISABLE  CBHNDL, %IDC_BUTTON2
        CONTROL DISABLE  CBHNDL, %IDC_BUTTON3
                    PARSEFILE(CBHNDL,InputFile)
                    MSGBOX "Finished"
        CONTROL ENABLE CBHNDL, %IDC_BUTTON1
        CONTROL ENABLE CBHNDL, %IDC_BUTTON2
        CONTROL ENABLE CBHNDL, %IDC_BUTTON3
                    END IF
                CASE %IDC_LABEL1
                CASE %IDC_LABEL3
                CASE %IDC_LABEL4
            END SELECT
    END SELECT
END FUNCTION
'   ** Dialogs **
    LOCAL lRslt AS LONG
#PBFORMS BEGIN DIALOG %IDD_DIALOG1->->
    LOCAL hDlg  AS DWORD
    DIALOG NEW  hParent, "G-Code to DXF", 73, 156, 274, 94, %WS_POPUP OR _
        %WS_BORDER OR %WS_DLGFRAME OR %WS_CLIPSIBLINGS OR %WS_VISIBLE OR _
        %DS_MODALFRAME OR %DS_CENTER OR %DS_3DLOOK OR %DS_NOFAILCREATE OR _
        %DS_SETFONT, %WS_EX_WINDOWEDGE OR %WS_EX_CONTROLPARENT OR _
        %WS_EX_LEFT OR %WS_EX_LTRREADING OR %WS_EX_RIGHTSCROLLBAR, TO hDlg
    CONTROL ADD BUTTON, hDlg, %IDC_BUTTON1, "Import G-Code", 5, 10, 65, 15
    CONTROL ADD BUTTON, hDlg, %IDC_BUTTON2, "Convert to DXF", 5, 45, 65, 15
    CONTROL ADD LABEL,  hDlg, %IDC_LABEL1, "None", 10, 30, 255, 10
    CONTROL ADD LABEL,  hDlg, %IDC_LABEL3, "Line : ", 80, 50, 25, 10
    CONTROL ADD LABEL,  hDlg, %IDC_LABEL4, "", 110, 50, 155, 10
    CONTROL ADD BUTTON, hDlg, %IDC_BUTTON3, "Exit", 205, 70, 50, 15
#PBFORMS END DIALOG
InitUrlCtrl ' INI for URL's
CONTROL ADD "PBURL32", hDlg, 106, "By Wayne Hill;mailto:wayne_j_hill@yahoo.com", _
                10, 70, 80, 14, %WS_VISIBLE OR %WS_CHILD
    DIALOG SHOW MODAL hDlg, CALL ShowDIALOG1Proc TO lRslt
#PBFORMS BEGIN CLEANUP %IDD_DIALOG1
#PBFORMS END CLEANUP
    FUNCTION = lRslt
END FUNCTION
  LOCAL TmpAsciiz AS ASCIIZ * 256
  GetModuleFileName GetModuleHandle(BYVAL 0&), TmpAsciiz, 255
  IF Op = 1 THEN
     FUNCTION = TmpAsciiz
  ELSE
     LOCAL i AS LONG, j AS LONG
     DO
        j = INSTR(i + 1, TmpAsciiz, "\")
        IF j = 0 THEN EXIT DO ELSE i = j
     LOOP
     IF Op = 2 THEN FUNCTION = LEFT$(TmpAsciiz$, i) ELSE _ ' With final \
        FUNCTION = MID$(TmpAsciiz$, i + 1)
  END IF
END FUNCTION
        DIM TypNew AS TypPoints
      DIM MyResults AS TypPoints
        DIM lNumberOfLines AS LONG
        DIM lNumberofAlpha_Codes AS LONG
        DIM lLineCount AS LONG
        DIM lAlphaCode_Count AS LONG
        DIM lAlphaCodePos AS LONG
        DIM lAlphaValue AS LONG
        DIM sLine AS STRING
        DIM sLineParsed AS STRING
        DIM sAlphaCode AS STRING
        DIM sGMode AS STRING
        LOCAL ArcCenterX AS SINGLE
        LOCAL ArcCenterY AS SINGLE
        LOCAL SideXs AS SINGLE
        LOCAL SideYs AS SINGLE
        LOCAL Radius AS SINGLE
        LOCAL AngleEnd AS SINGLE
        LOCAL AngleStart AS SINGLE
        LOCAL LineCounter AS LONG
        LineCounter = 48 ' Start at 48 for AutoCAD Line Number Entity
        DIM HFILE AS LONG
        DIM sBUFFER AS STRING
        DIM sTemp AS STRING
     TypOld = TypNew ' Clear
        HFILE = FREEFILE
        OPEN SMYSOURCEFILE FOR INPUT AS HFILE
        WHILE ISFALSE EOF( HFILE )
            LINE INPUT# HFILE, sTemp
        CONTROL SET TEXT  hWnd , %IDC_LABEL4,  sTemp
        sBUFFER = sBUFFER + sTemp + $CRLF
DIALOG DOEVENTS
        WEND
        CLOSE HFILE
        HFILE = FREEFILE
        OPEN "Data.DXF" FOR OUTPUT AS HFILE         'DXF FILE.
        PRINT #HFILE, "  0"
        PRINT #HFILE, "SECTION"
        PRINT #HFILE, "  2"
        PRINT #HFILE, "ENTITIES"
        lNumberOfLines = TALLY( sBUFFER, $CRLF )
        FOR lLineCount = 1 TO lNumberOfLines
      DIALOG DOEVENTS
      CONTROL SET TEXT  hWnd , %IDC_LABEL4,  STR$(lLineCount)
            sLine = PARSE$( sBUFFER, $CRLF, lLineCount )
            sLine = PARSE$( sLine, "(", 1 )         ' REMOVE COMMENT LINE
            sLine = UCASE$( sLine )         ' CHANGE TO UPPERCASE
            sLine = REMOVE$( sLine, " " )       ' REMOVE SPACES
            lNumberofAlpha_Codes = TALLY( sLine, ANY $ALPHA )
            FOR lAlphaCode_Count = 1 TO lNumberofAlpha_Codes
                lAlphaCodePos = INSTR( - 1, sLine, ANY $ALPHA )         ' FIND THE RIGHTMOST LETTER
                sLineParsed = MID$( sLine, lAlphaCodePos, LEN( sLine ))         '  GET THE CODE AND THE VALUE
                sLine = EXTRACT$( sLine, sLineParsed )      ' REMOVE IT FROM THE MAIN STRING
                sAlphaCode = LEFT$( sLineParsed, 1 )
                SELECT CASE sAlphaCode
                    CASE "X"
                        TypNew.X = VAL( FORMAT$( VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 )), $DP ))
                    CASE "Y"
                        TypNew.Y = VAL( FORMAT$( VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 )), $DP ))
                    CASE "Z"
                        TypNew.Z = VAL( FORMAT$( VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 )), $DP ))
                    CASE "R"
                        TypNew.R = VAL( FORMAT$( VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 )), $DP ))
                    CASE "I"
                        TypNew.I = VAL( FORMAT$( VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 )), $DP ))
                    CASE "J"
                        TypNew.J = VAL( FORMAT$( VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 )), $DP ))
                    CASE "G"
                        lAlphaValue = VAL( PARSE$( sLineParsed, ANY $ALPHA, 2 ))
                        SELECT CASE lAlphaValue
                            CASE 0
                                sGMode = "0"        ' Group 1 G Codes
                            CASE 1
                                sGMode = "1"
                            CASE 2
                                sGMode = "2"
                            CASE 3
                                sGMode = "3"
                        END SELECT
                END SELECT
            NEXT ALPHACODECOUNT
            IF sGMode = "3" OR sGMode = "2" THEN
                    IF TypNew.R <> 0 THEN
                        MyResults.X1 = TypOld.X
                        MyResults.Y1 = TypOld.Y
                        MyResults.X2 = TypNew.X
                        MyResults.Y2 = TypNew.Y
                        Radius = TypNew.R
                        MyResults.R = ABS( Radius )
                  CalcCenters MyResults
                        IF ( sGMode = "2" ) AND ( SGN( Radius ) = - 1 ) THEN
                            ArcCenterX = MyResults.X2
                            ArcCenterY = MyResults.Y2
                        END IF
                        IF ( sGMode = "2" ) AND ( SGN( Radius ) = 1 ) THEN
                            ArcCenterX = MyResults.X1
                            ArcCenterY = MyResults.Y1
                        END IF
                        IF ( sGMode = "3" ) AND ( SGN( Radius ) = - 1 ) THEN
                        END IF
                        IF ( sGMode = "3" ) AND ( SGN( Radius ) = 1 ) THEN
                        END IF
                  GOTO PlotPoint
                    END IF
    IF ( TypNew.I <> 0 ) OR ( TypNew.J <> 0 ) THEN
                    ArcCenterX = TypOld.X + TypNew.I
                    ArcCenterY = TypOld.Y + TypNew.J
    END IF
PlotPoint:
                MyResults.X1 = ArcCenterX       ' Center of Circle
                MyResults.Y1 = ArcCenterY
                MyResults.X2 = TypOld.X         ' Point in Radius
                MyResults.Y2 = TypOld.Y
                CalcAngle MyResults
                AngleStart = MyResults.ang
                MyResults.X2 = TypNew.X         ' Point in Radius
                CalcAngle MyResults
                AngleEnd = MyResults.ang
                TypNew.R = MyResults.r
                IF sGMode = "3" THEN
                    IF AngleStart = > AngleEnd THEN AngleEnd = AngleEnd + 360
                END IF
                IF sGMode = "2" THEN
                    IF AngleStart < = AngleEnd THEN AngleEnd = AngleEnd - 360
                END IF
                PRINT #HFILE, "  0"
                PRINT #HFILE, "ARC"
                PRINT #HFILE, "  5"
                PRINT #HFILE, HEX$( LineCounter )
                PRINT #HFILE, "100"
                PRINT #HFILE, "AcDbEntity"
                PRINT #HFILE, "  8"
                PRINT #HFILE, "0"
                PRINT #HFILE, " 62" ' Line Color Format
                PRINT #HFILE, "     " + STR$( 45 ) ' Line Color
                PRINT #HFILE, "100"
                PRINT #HFILE, "AcDbCircle"
                PRINT #HFILE, " 10"
                PRINT #HFILE, ArcCenterX
                PRINT #HFILE, " 20"
                PRINT #HFILE, ArcCenterY
                PRINT #HFILE, " 30"
                PRINT #HFILE, TypOld.Z
                PRINT #HFILE, " 40"
                PRINT #HFILE, TypNew.R
                PRINT #HFILE, "100"
                PRINT #HFILE, "AcDbArc"
                PRINT #HFILE, " 50"
                IF sGMode = "2" THEN PRINT #HFILE, AngleEnd
                IF sGMode = "3" THEN PRINT #HFILE, AngleStart
                PRINT #HFILE, " 51"
                IF sGMode = "2" THEN PRINT #HFILE, AngleStart
                IF sGMode = "3" THEN PRINT #HFILE, AngleEnd
                INCR LineCounter
                TypOld.X = TypNew.X
                TypOld.Y = TypNew.Y
                TypOld.Z = TypNew.Z
            TypNew.R=0
            TypNew.I=0
            TypNew.J=0
                ITERATE FOR
            END IF
            PRINT #HFILE, "  0"
            PRINT #HFILE, "LINE"
            PRINT #HFILE, "  5"
            PRINT #HFILE, "100"
            PRINT #HFILE, "  8"
            PRINT #HFILE, "0"
            PRINT #HFILE, "100"
            PRINT #HFILE, "AcDbLine"
            PRINT #HFILE, " 10"
            PRINT #HFILE, TypOld.X
            PRINT #HFILE, " 20"
            PRINT #HFILE, TypOld.Y
            PRINT #HFILE, " 30"
            PRINT #HFILE, " 11"
            PRINT #HFILE, TypNew.X
            PRINT #HFILE, " 21"
            PRINT #HFILE, TypNew.Y
            PRINT #HFILE, " 31"
            PRINT #HFILE, TypNew.Z
            INCR LineCounter
            TypOld.X = TypNew.X
            TypOld.Y = TypNew.Y
            TypOld.Z = TypNew.Z
        NEXT lLineCount
        PRINT #HFILE, "  0"
        PRINT #HFILE, "ENDSEC"
        PRINT #HFILE, "  0"
        PRINT #HFILE, "EOF"
        CLOSE HFILE
    END SUB
    '   CalcCenters calculates the centers of two circles given their points
    '               of intersection and common radius.
        LOCAL c AS TypPoints        ' Points of intersection
        LOCAL H1!, H2!, K1!, K2!, X!, Y!, D!, D2!
        c = Centers
        X = c.x1 - c.x2
        Y = c.y1 - c.y2
        D2 = X^2 + Y^2
        D = SQR( D2 )
        IF 2 * c.r < D, THEN        ' values of H and K are not real
            c.x1 = 0!       ' and there is no solution.
            c.x2 = 0!
            c.y1 = 0!
            c.y2 = 0!
            c.r = 0!
            Centers = c
            EXIT SUB
        END IF
        K1 = ( Y + X * SQR( 4 * c.r^2 / D^2 - 1 )) / 2
        K2 = ( Y - X * SQR( 4 * c.r^2 / D^2 - 1 )) / 2
        H1 = ( X^2 - Y * ( 2 * K1 - Y )) / ( 2 * X )
        H2 = ( X^2 - Y * ( 2 * K2 - Y )) / ( 2 * X )
        h1 = H1 + c.x2
        h2 = H2 + c.x2
        k1 = K1 + c.y2
        k2 = K2 + c.y2
        c.x1 = h1
        c.x2 = h2
        c.y1 = k1
        c.y2 = k2
        c.r = c.r
        Centers = c
    END SUB
    '   CalcAngle calculates the angle of radius given
    '         center of circle to point on circomeference.
        LOCAL c AS TypPoints        ' Radius and Angle of circle
        LOCAL X!, Y!, R!
        c = tPoints
        X = c.x2 - c.x1
        Y = c.y2 - c.y1
        c.r = SQR( X^2 + Y^2 )      ' Hyp of angle (Radius)
        IF c.r = 0 THEN         ' values are not real
            c.x2 = 0!
            c.y1 = 0!
            c.y2 = 0!
            c.r = 0!
            c.ang = 0!
            tPoints = c
            EXIT SUB
        END IF
        ' Find quadrant of angle in radians
        IF x = 0 THEN
            IF y > = 0 THEN
                c.ang = PI / 2
            ELSE        ' Y
                c.ang = 3 * PI / 2
            END IF      'Y
        ELSE        ' X
            c.ang = ATN( Y / X )
        END IF      'X
        IF X < 0 THEN
            c.ang = c.ang + PI
        ELSE
            IF ( x > 0 ) AND ( y < 0 ) THEN
                c.ang = c.ang + 2 * PI
            END IF
        END IF
        c.ang = c.ang * 180 / pi        ' Convert to Decimal Degrees
        tPoints = c
    END SUB
