Ok..
Here is a cut-out from my servo manufacturers page on hooking up the "Encoder Simulation" port to the cnc controller.
Keep in mind that the motor has a "Resolver" that hooks up to the servo drive. The servo drive has an "Encoder Simulation" port that gets wired to my ICM2900 from Galil.
But the manufacturer does not specifiy what each pin is. They only reference them as shown in the drawing.
The ICM2900 has +max, -max, +mbx, -mbx, +inx, -inx, +5v, gnd.
I would assume that max is A chanel, mbx is B channel. but what about the 3rd set of twisted pairs that are marked as C and C- on the servo drive module? Do those go the [inx] ?? The servo resolver has an Excite channel also.. Is that the C and C- ??
The system seems to work with just the A an B channels hooked up but I wonder if I did the right thing or not by leaving the C channel unhooked.
Any suggestions? |
