So this has an Acroloop card?
I have a couple of machines I retrofitted using Acroloop, what is the model of the card?
Probabally a ACR8000?
You can disconnect the analogue to the motor drives separately from the encoder input.
It is the large D plug on the bracket end of the card.
If you can go to a DOS prompt, you can test the card with a service program, or fit it in an ISA slot PC that runs DOS.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
