Thread: Newbie cambam problem
Old 10-03-2009, 11:43 PM
Starleper1 Starleper1 is offline
Starleper1 is on a distinguished road
Click on the object in CamBam and then go under tool and click "Object Extremes"
Make sure that this doesn't exceed your limits. Sometime if you import an .STL file the scale will be way off and you will need to scale it to your desired size.
If your not cutting 3D and only importing DXF then this shouldn't be the issue but just give that a try.
