Claya is correct...the arm has slipped on the shaft. This is not keyed as it would cause much damage if it were. It is a taper fit like a tool holder. Once it is loose you can tap it around untill it is alligned properly. I've had to do this before due to a tooling jam durring tool change.
__________________ We all live in Tents! Some live in content others live in discontent. |
