  #12   Ban this user!
Old 09-30-2009, 05:41 PM
stk2008 stk2008 is offline
stk2008 is on a distinguished road
hi all im still having problems i can not get cambam to import the correct size of the r12 dxf file if i set it to X amount in inkscape etc i then import to cambam set me pathes then export to mach 3 its way to big.
i export from inkscape in inches into cambam tho both programs are set to use inches. i then use the measure tool in cambam and its allways in mm i know this because the dimension i get if i devide that by 25.4 it gives me the same size i set in inkscape.
all ok u may think but no as mach3 is set to inches to there for that lets say 4" from inkscape = 101.6mm in cambam tho i have set it to inches if i leave it i then send it of to mach3 so mach3 sees it as 101.6 inches doh.
any ideas please why cambam wont see it as inches when i open up the dxf file from inkscape
