Thread: Problem TORQ-CUT 22 Problems
Old 09-28-2009, 08:10 PM
tpmx57 tpmx57 is offline
tpmx57 is on a distinguished road
George,
I checked out the mill tonight.
I found the battery,its marked VARTA 3.6v 60mah Ni-Cad.
I don,t see any leakage but right behind the motherboard the cabinet has black smoke marks,this is right where the battery is located.
There is also a 2-wire plug there that is ran up to a TAIRAN 3.6v High Energy Lithium battery that is mounted to the cabinet right above the motherboard.
I can just imagine what the back side of the MB looks like in the area behind the ni-cad.
Right now the machine boots up with a KB error and I can press F1 and it will boot on up.
Then I get the e-stop pressed error that I can,t get around.
Is it possible to find replacement motherboards that will work with the machine?
I would like to replace the MB,video card and harddrive and put the originals away.
I have copied the harddive before just to be safe.
Thanks!
