Update: Well my problem has nothing to do with a #83 or #84 error. It is a programming problem. I guess I should say it's a Post processors and or the machine controllers capabilities problem. Way to go Bridgeport! Post a oil pump error when the controller does not know what to do!!
Anyway, the machine stops (shuts the drives, coolant, and spindle off) at the end of a tool path. If I skip the line it stalls on then it will run, but I have input an addtional S code for the spindle to turn on then it stalls again in the same place. The operation is a ramp contour with 4 passes. It stalls at the end of each contour. Here is a small bit of the code. From here I am going to the mastercam forum and giving the guy who wrote the PP a call. So I guess the lesson learned for me is, always test the machine with a program you know it runs properly before paying to close attention to any errors.
Thanks,
CD
N1370 G99 X1.1038 Y-.727 Z-.898
N1380 G99 X.2316 Y-.727
N1390 G99 X-.21 Y-.6491
N1400 G99 X-.21 Y.21
N1410 G99 X1.16 Y.21
N1420 G99 X2.744 Y.21
N1430 G99 X2.744 Y-.362
N1440 G99 X2.744 Y-.4395
N1450 G99 G3 X3.494 Y-1.1895 I3.494 J-.4395
N1460 G99 G1 X4.244 Y-1.1895
N1470 G99 X4.244 Y-1.1895 Z-.798 F6.4 (STOPS HERE)
N1480 G0 Z.25 (WILL NOT RUN) (IF I JUMP TO THIS LINE AND INPUT A SPINDLE SPEED, IT WORKS)
N1490 G0 X4.194 Y.3105
N1500 G0 Z.127
N1510 G99 G1 X4.194 Y.3105 Z.027
N1520 G41 G48 X4.194 Y.3105 F18.3
N1530 X4.194 Y.3105
N1540 G99 X3.444 Y.3105 |
