Old 09-28-2009, 08:54 AM
LockTech LockTech is offline
LockTech is on a distinguished road
Trying to set origin coordinates
I have a piece that is going to require a few manual tool changes, therefore I am wanting to run these as seperate gcodes.
I created a fixture and now I am wanting to clamp an item into that fixture and run several different steps on it using the original alignment I used to produce the fixture. So now I have different layers saved as DXF's and I made a starting point in the same place on each layer. However I dont know how to tell LazyCam to make that starting point a certain X,Y coordinate?
Did all that make sense?
Also, how do I change the direction of a cut? For example I have a straight pocket the same width as the bit. LazyCam is automatically setting it up to run right to left because its closer to the starting point. But, I want it to cut from left to right, is there a way to tell LazyCam to switch the direction?
