Originally Posted by djem I took a closer look at the dremel knockoff I had planed to use as a spindle to start with. It turns out that the runout on this thing is a little bigger that I had anticipated and might not work very well for PCB milling. Is there any hope that a real dremel is going to be much better, or should I start looking for a more professional solution? cnconabudget got a interesting one, but its 110V so I would need a converter to use it (I'm on a 220V net). Any tips on what I can use, it has to take 3,2mm (1/8") tools to be suitable.
I don't have equipments to measure the runout, but as I could see it with my naked eye I'm guessing it is close to 0,5mm. Might work for some of the simpler PCB designs with no surface mounts, but I don't want the spindle to be my limiting factor. I'm guessing the roller bearing design might end up as the limiting factor? |
the cnconabudget spindle will give you much finer pitch pcb traces over a dremel.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com |
