Am I missing something here or is there only one chase line
"All I wanted to do was run two threads with a .020" bigger diameter between them." ????????????????????
are you trying to run a double lead thread with different pitch diameters?
if not what are you trying to attempt?
I am guessing that you are altering the program between threads?
Have altered both the N90 line to reflect below?
N90G00X.270Z.20
and the N100 line to reflect the below?
N100G78X.205Z-.700P0325Q0120F.035
If you are altering the thread cycle between threads make sure these two lines are correct if they have wrong numbers this may caues problems? |
