Old 09-26-2009, 03:21 PM
heilcnc heilcnc is offline
Gold Member
heilcnc is on a distinguished road
USED MINI LATHE HEADSTOCK AND TAIL STOCK
1 USED HEADSTOCK OFF A C1 MINI LATHE(SHOP FOX M1015) AND TAIL STOCK WITH MT#1 DEAD STOP THE HEADSTOCK COMES WITH ADAPTER TO MOUNT STANDARD "3 MINI LATHE CHUCK (PN-1187 YOU CAN GET FROM LITTLE MACHINE SHOP NO CHUCK INCLUDED!!!!) THE HEADSTOCK HAS MT#2 TAPER IN FRONT "3/8 BORE THRU HAS 28 TOOTH XL TIMING BELT PULLEY I ADDED TO IT EASLY REMOVED THIS WOULD BE GREAT TO MAKE 4TH AXIS OUT OF IT PRETTY SMALL HAS 4 BOLT HOLES ON FLAT BOTTOM OF HEADSTOCK ALLSO HAS KEYWAY RIGHT IN MIDDLE OF BOLT HOLES SHIPPING IN THE USA ONLY!!!!!!!!!!!!!!!!!!!!!!!!!! BIDDING STARTS AT $50. SHIPPING $9.75 FLAT RATE http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=STRK
