Old 09-25-2009, 05:08 AM
CarveOne CarveOne is offline
CarveOne is on a distinguished road
Mount the motor and coupler outside the front or rear of the machine's base plate and use a longer lead screw to make use of more of the travel capability. You can put a sheet aluminum cover over the motor and coupler to keep dust and debris off of it if you wish to.
For the gantry beam, a piece of 8020 extrusion would be much stiffer than a single layer of MDF. If not that, double the thickness of the beam with two layers of MDF for improved resistance to twisting under loads.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
