Thread: spigot failure
Old 09-24-2009, 04:03 PM
dahun dahun is offline
dahun is on a distinguished road
Originally Posted by BBRC View Post
I am wondering if there is A "phasing" on the install.Do the switches need to be timed?Activated together at A certain point. wires are all good.Messing with machine manually brought it all the way down let the machine bring it back up and count the positions and it worked for 10 min,now not so.My HFO went out of buisness customer service was outstanding there,and the techs would have this resolved allready through A phone call.I dont even know if you can get parts in A timely manner here now.
There is nothing you can tweek on the inside. There is no phasing either... It's all pretty simple stuff really. Often I see a lot of corrosion that builds up around the black shaft in the back. What gets me is that it worked well up to this point (?) and now it quit.
Disconnect the cable from the unit. You can manually run the unit (by rotating the large spur gear) and check that each lobe of the small cam actuates the counting switch by listening to the click. Also you can check that the homing switch mounted on the casting actuates when the cam pushes back on it. You should also feel more resistance to turning of the large spur gear when the switch engages. If you have both switches working, chances are good that it's not the pcool. Again, make sure that the black shaft rotates freely. You said that the motor moves the nozzle, so the motor is okay.
We have had I/O board issues with regards to the PCOOL circuit. This would require you to have a HFO tech out there... IF and when the tech comes out, have him demonstrate to you that the new board will work.
Let me know if this helped.
Please check this out:
Name:	PCOOL_trouble shooting.jpeg‎
PCOOL dude...
