My existing milling cnc machine is 100 volt DC for the servos. If I use a 100 volt Rutex drive then what is the recommended voltage to use. The way I see is that using the same power supply will fault the drive due to back emf when motor is decelerating. Need your recommendation.
Reason: typo
