Thread: x axis setup
Old 09-22-2009, 02:48 PM
amishx64's Avatar
amishx64 amishx64 is offline
amishx64 is on a distinguished road
Lightbulb Two Steppers on One Driver
Originally Posted by pminmo View Post
The real reason to use a dual screw is racking. If your mechanics are such that racking isn't an issue, one motor is more efficient. i.e. two motors developing the same force as one motor won't run as many rpm's as the one motor.
Can't you just connect the motors in series or parallel? That's what I'd do. Then you wouldn't have any controller discrepancies, and you could run both just as you were running only one.
