preprogrammed coordinate programming? | | I’m looking for some advice on how I might set up a Cartesian style robot to simply go to preset coordinates when a button or keyboard key is hit. I’d like to set it up so that I can have a dozen points in the X and Y axis and can get a probe to jump to each one when that particular button is pressed. Lastly A button to zero the machine on startup.
Any suggestions as to what I could use as a controller? I would use steppers for motion and perhaps a PC to control the step/Dir signals. Any suggestions to a simple software solution that could do this?
I've built a couple of CNC machines and most of run from Mach 2 on a PC. I just don't have any experience with software other then this.
Thanks, Lawrence |
