Press the manual key. then press the key for machine diagnostics. Once you get into diagnostics press enter-642-enter. Press the key to load the default values. If you're lucky, the previous owner stored the ball screw values on one of the floppy disks and you can use the same technique to load the real values from the disk. I store those values on every floppy I use as a backup |
