Originally Posted by vegas705 Yes there is a offset value in g54 should i set that to 0.00. also once all tools are set can i still use g54 or do I need to use another offset such as g55 or g56 |
Go into your Settings and find Setting 64
T. OFS Meas Uses Work.
I think you will find it is OFF.
Turn it on and now when you use Z Face Measure the value in the G54 offset will be subtracted from the work offset value that goes into the work offset table.
Then you can use G54 as you have been doing.
I think this is correct, turn your rapids down and single block to make sure things are the way you want.
