Set that switch to FULL and try it.
Whichever position gives the higher holding torque, use that one.
Just turn against it with your hand. You should feel the difference.
That was not in the document file I read.
Rotating by hand during setting up a job, getting the chuck to a convenient position to use the chuck key. In your application there may be no need for this, but the driver has the feature.
Unplugging a stepper while the power is on can kill the driver. That's one reason the enable signal is useful.
If you need to disconnect the drive, you can disable it, then unplug it without frying the driver.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
