Originally Posted by quadmasta Which? In the free plans, if I were to want to make the resolution a little longer in either the x or the y axis I would just need to add the appropriate length to the table, the leadscrew, and the guide rods, correct? |
It's usually never as simple as just making everything a litlle longer. I believe the free plans machine uses unsupported shafting as guides. Adding length can increase flexing. If you're not careful, it could make the machine unuseable. There's a reason that most of the inexpensive wood machines are all a similar size. It's difficult to buils a large machine cheaply.
